Repair Help
ID
Hello-
I bought a Hangar 9 Alpha 40 airplane some weeks ago and I crashed and I fixed the engine with some parts
But now I need new pushrods
Which ones would you recommmend?
Thank you
Sebastian
Thank you
Sebastian
My Feedback: (12)
TX
Which pushrods do you have to replace? Your local hobby shop has .047 pushrod material. Various lengths, threaded on one end, so you can make them up yourself.
You can also call Horizon Hobby. They sell the Alpha 40. You can do a search "RC Airplanes" Hangar 9, Alpha 40.
Click on "Description" and it will take you to a more detailed view of the 40. You will find you can download the
owners manual there. However, it does not show the pushrods, niether does the parts listing.
It's either call Horizon or go to your local hobby shop. You can make them up for yourself.
http://www.horizonhobby.com
I second the call Horizon/Hanger 9. I have an AT-6 and found their customer support to be very helpful when I had some assembly questions. You can probably order the pushrods right from them.
They may be 2-56 or they may be metric like a lot of stuff that gets produced overseas. Do not put metric clevis's on non-metric (SAE) wires. It will seem to fit but can slip and fail. To be sure whenever replacing a pushrod like this, change out all components from end-to-end.
