 Cleaner >
Cleaner
Cleaner
Old 06-25-2006 | 09:29 PM
Default Cleaner
What is a good cleaner or homemade mixture for cleaning the oil residue off of covering on a plane. I have tried different brands of mainly glass cleaners and want something that well remove all the oil.
Old 06-25-2006 | 09:36 PM
Default RE: Cleaner
Krud-Cutter...from home depot. 1 gallon of concentrate will last you several years even if you fly every day.
Old 06-25-2006 | 09:43 PM
8D3
Default RE: Cleaner
You can add rubbing alcohol to the glass cleaner to help cut the residue.
Old 06-25-2006 | 09:52 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Cleaner
Gallon of windshield washer fluid with a couple of squirts of Dawn dishwashing liquid in it.
Ken
Old 06-25-2006 | 11:04 PM
My Feedback: (7)
Default RE: Cleaner
krud cutter? Never heard of it. How good does it work as opposed to alcohol or windex?
Old 06-26-2006 | 05:23 AM
piper_chuck's Avatar
My Feedback: (12)
Default RE: Cleaner
I use Simple Green. Bought a gallon bottle that came with a couple spray bottles, lasts a long time.
Old 06-26-2006 | 06:37 AM
Default RE: Cleaner
Simple green is pretty good stuff for just about any clean up, 409 seems to work well too. They both have some kind of grease cutters in them. I may have to give the ol' krud-cutter a try though. I had never heard of it either.
Old 06-26-2006 | 03:52 PM
My Feedback: (14)
Default RE: Cleaner
I found a product called "Terrific Orange Cleaner" - available at "Dollar Stores" and discount stores that works real well.
A real quick and good home brew can be made as follows:
Take an empty gallon jug. Add a pint of rubbing alcohol, about 4 ounces of ammonia and an ounce or so of liquid dishwashing soap. Then fill the jug with water and you have a really good cleaner.
The ammonia really does a good job of cleaning off oil residue.
Old 06-26-2006 | 04:09 PM
Default RE: Cleaner
Thanks for the info.
Old 06-26-2006 | 10:34 PM
Chocks's Avatar
Default RE: Cleaner
Klumsy was close, winshield cleaner, amonia, and rubbing alcohol and a small squirt of dawn. One thing that nobody has mentioned is do NOT use paper towels on Monocote. Go to Costco or Sams and buy a buddle of terry cloth rags. It will save you alot of scatches on your Monocote, especially on dark colors.
Old 06-27-2006 | 07:39 AM
Default RE: Cleaner
window cleaner works great...spray it on whipe it off all clean....
