 Engine question >
Engine question
Engine question
Old 07-22-2006 | 11:55 AM
niteowl5001's Avatar
Default Engine question
I have a YAK 54 140 size. What engine should I get? I have all os engines now 4- .46.s, 1-.61 I
1) I want to put an OS 160($299) in it, but I like the
2) SAITO 125 (More expensive). I've never had a gas engine but I was thinking about getting a
3) Fuji Imvac. What do you guys think?
Old 07-22-2006 | 12:50 PM
Default RE: Engine question
Hi!
MVVS 26cc (160) gas or glow.
ID:	495171   Click image for larger version
Old 07-22-2006 | 01:54 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
If I had my druthers I would put a gas engine in a plane that big. The fuel costs alone make it worth while. Glow fuel at ~$16/gallon as opposed to gasoline at ~$3/gallon. No brainer in my opinion. I'm through buying glow engines for just this reason. My glow fuel bills last year were right around $750 and I'd like to knock that down a bit by going with gas.
Hope this helps
Ken
Old 07-22-2006 | 02:40 PM
Thanks Ken and Jaka, I will get a gas engine. Now a couple of questions. I have never had any problems with my OS engines. Can I expect the same reliablity from gas?
Old 07-22-2006 | 03:57 PM
Expect better reliability.
Regards,
doubledee
Old 07-22-2006 | 03:58 PM
RCKen's Avatar
My Feedback: (9)
Definitely better with gas.
Ken
Old 07-22-2006 | 04:19 PM
B.L.E.'s Avatar
There's a lot less goo to clean off at the end of the day with gasoline powered engines. If I built a plane that big, it would be gas.
Old 07-22-2006 | 09:40 PM
Thanks guys, Gas it is. How about the Zenoah G26. 26cc's
Old 07-23-2006 | 11:48 AM
hi,
i have a kyosho spitfire ARF, 40 size for 2 stroke engine.
i want to put in 4 stroke engine, which engine size is suitable?
please halp me....
Old 07-23-2006 | 01:14 PM
probably a .70 size 4 stroke would be at the upper end and a .61 at the lower end.
Old 07-23-2006 | 01:46 PM
Hi!
Saito .56 and 12x6 APC ...In reply to what is best 4-stroke for a Kyosho .40 warbird.
As for what is more reliable gas or glow...that's simple... gas.
I admit that big 26cc glow engines like MVVS and OS are very reliable , my MVVS 25cc glow engine in my SIG CAP 231 EX hasn't malfunctioned or stopped once prematurely in 4 years running and has a very reliable low idle at 1800-2000 rpm. But a gas engine is even more reliable and it's cheaper in the long run och cleaner too.
ID:	495679   Click image for larger version
ID:	495680   Click image for larger version
ID:	495681   Click image for larger version
ID:	495682   Click image for larger version
Old 07-23-2006 | 06:20 PM
Cyclic Hardover's Avatar
ORIGINAL: RCKen
Ken
I think my glow bill in the last year is about $32. Still working on the second gallon. I fly for quality not quantity. Been real busy. I go out about every other week. Stick a "Extreme Speed" up in the air for 5 minutes. Then say "phew" that felt like 3 hours and go home.
Old 07-23-2006 | 06:25 PM
RCKen's Avatar
My Feedback: (9)
ORIGINAL: Cyclic Hardover
ORIGINAL: RCKen
Ken
Cyclic,
Even though I fly a lot, I too fly for quality. There are days I will go out and fly one flight and then sit in the stands the rest of the day talking with buddies. Then there are days I will go out and fly 10-15 flights, but it doesn't have anything to do with quantity. It's what I feel like flying that day.
Ken
Old 07-23-2006 | 07:55 PM
thank you very much jaka and aerowoff.
