how does te bottom of a four stroke get lubricated????
ON, CANADA
how does the bottom of a four stoke get lubricated cause the fuel comes in through the top of the engine combust and goes out the top of the engine so how does oil get down there???
cause i have a four stroke that was built about 15 years ago and i took it apart to clean it cause it sat for a long time and the bottom was filled with grease and i phoned a local hobby shop and he said that there should never be any grease in there so im not sure wether to put grease back into it or take his advice
chris
p.s this is a o.s. fs60 and is ment for a boat and i was told i would have more help in this section
chris
chris
chris
A four stroke gets all it's oil from blow by. Some of the fuel blows by the ring on compression and ends up in the crank case. Some blows by the valves and ends up lubercating the rockers and valve stem and some runs down the push rods and gets the lifters and cam. Oil that is slung around inside the crank case lubes the bearings and con rod. All fourstrokes have a vent on the crankcase, some two. Excess oil and preasure is vented out. My Magnum 52 just dripps out of a single vent near the nose of the crank case. The Magnum 70 has a PCV setup with the vent going to the intake manifold. What exits the vent is sucked back into the intake an burnt off.
I suspect that what you saw is a buildup of oxidized oil. An engine couldn't run with a case full of grease. The maximum RPM would be in the low hundreds not over 10K, and it would likely blow the crank case apart. The local hobby shop guy knew what he was talking about. Clean everything up and if the bearings are dry, put a couple drops of castor oil on them. You can get a small bottle at most drug stores. All you want is enough so the engine isn't dry when it first starts up. Kind the same as you would do when rebuilding a car motor. As soon as it starts running fresh oil will be supplied, so all you want is just a drop or two on each bearing, including the cam bearings and a couple on the cam its self. If you took apart the top end and cleaned it, do the same for the rocker arms and pushrod ends. Don't make it sloppy with oil, just enough so it isn't running dry when it fisrt fires off.
Don
ON, CANADA
thanks for ur helpits my grandpa's boat that he built before he past away so i don't want to mess anything up
thanks so much
chris
thanks so much
chris
