 which servo should i use? >
Old 08-10-2006 | 11:57 AM
Default which servo should i use?
I have the giant scale hellcat, with 70" wingspan and century jet air retracts, what Hitec retract servo should i use for the valve, also are the air tanks re fillible and how many cycles can they go through before i should refill my air tank.
Thanks, Dave Trimmer
Old 08-10-2006 | 01:33 PM
MinnFlyer's Avatar
Default RE: which servo should i use?
If they are air retracts you don't need a retract servo, just a standard one to operate the valve.
As far as "how many cycles" you'll have to experiment (On the ground) to find out how many you can safely do.
