Taking the prop off >
Taking the prop off
Taking the prop off
Old 01-08-2003 | 12:29 AM
Default Taking the prop off
I have a firebird xl electric plane and I need to take the prop off but I can't figure out how to do it!! There is no nut like a standard prop. The only way I can see to do it is to just pull, but it isn't budging. Can someone help me?
Old 01-08-2003 | 12:50 AM
pull... it is only held on by friction. (only take it off if you are replacing the prop or engine, if stays on fairly well by itself, but you may have to CA it on if you remove it a couple of times
Old 01-08-2003 | 01:02 AM
THX. I am changing the propeller to a new fuselage. The old one got beat up in a failed corkscrew dive.
