 ENGINE PROBLEM >
ENGINE PROBLEM
ENGINE PROBLEM
Old 09-03-2006 | 09:19 PM
Default ENGINE PROBLEM
HI I am having some trouble with my thundertiger 25 when ever the engine is flicked over air is let into the fuel tubing and then after about three flicks the entire tube is empty of fuel any sugestions?
Old 09-03-2006 | 09:28 PM
Mr67Stang's Avatar
Default RE: ENGINE PROBLEM
Do you have your pressure line on the carb and the feed line on the muffler??? That could do it.
Old 09-03-2006 | 10:53 PM
no the lines are fed corectly this problem only developed lately
Old 09-03-2006 | 11:07 PM
Mr67Stang's Avatar
You can check the fuel lines in the tank for splits and holes. Do you have an electric starter? Spin it faster and see if fuel comes up the line. Or plug the exhaust port when you flip it a few times. Have you changed the location of your engine or feul tank. If your tank is to low in relation the the carburetor spray bar gravity might be your culpret. (spray bar is idealy center with the tank (you rarely get an ideal set up))
Old 09-04-2006 | 06:10 AM
piper_chuck's Avatar
My Feedback: (12)
Are you flipping with the throttle at idle or wide open? Idle is the proper position for starting an engine.
Old 09-04-2006 | 08:18 AM
I'll go with a crack or hole in the supply line. Possibly a clogged or kinked line. Don't forget to check the brass tubes in the tank, too.
Dr.1
