 Saito FA100 >
Saito FA100
Saito FA100
Old 09-11-2006 | 11:28 AM
swixtt's Avatar
Default Saito FA100
Hello folks,
i'm looking at install a FA100 into a plane i'm building and wondering what type of motor mounts you've used in the past? I'm pretty sure the Dave Brown FS90 will work but are there any others that are any better?
Also, what size of bolts did you use to mount it to the firewall(will be using the blind nuts with them)
thanks for listening...
Old 09-11-2006 | 02:39 PM
raideron's Avatar
Default RE: Saito FA100
swixtt..
Don't know about better, But I've used this one on my S-82/100 and
also on my YS 110... It's doing good....
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ773&P=7
Old 09-11-2006 | 06:23 PM
swixtt's Avatar
thanks... any idea on size of the bolts/blind nuts.
Old 09-11-2006 | 07:03 PM
I've been very happy with the Dave Brown. I drill the mount arms and tap for 6-32 hex head bolts, grind a flat spot on the bottom of the arms, then put locking nuts with washers on the ends of the bolts. Rock solid, never had anything come loose.
Old 09-11-2006 | 07:09 PM
swixtt's Avatar
what about the size on mounting to the firewall? #8's? with blind nuts??
thanks for the info about the rail mounting... i was thinking the same thing.
ORIGINAL: dmanson
Old 09-12-2006 | 12:15 PM
raideron's Avatar
swixtt... I just used what they had listed, which I think was 8-32 Blind Nuts/bolt
No problems to date... On my Showtime/YS-110 I got a bit longer bolts(Ace) and
added locknuts also... Not sure why, but that's what I did....
