Center of Gravity >
Center of Gravity
Center of Gravity
Old 01-11-2003 | 06:11 PM
8KCABrett's Avatar
Default Center of Gravity
Just wondering how you are "supposed" to measure CG. Its funy, I have been building and flying for 13 years, and I never actually found out. My question relates to using a flexible tape that measures from the leading edge following the curvature of the airfoil, vs. my top down method of laying a rigid tape or ruler flat against it and measuring there. Thus far my CG's have always been fine, but my latest model has a VERY short range and a thick foil.
Thanks in advance,
Brett
Old 01-11-2003 | 06:14 PM
My Feedback: (62)
Default Do you have the plans
If so maybe you can measure from the trailing edge forward?
Old 01-11-2003 | 11:55 PM
Flyfalcons's Avatar
Use the top-down method for best results.
Old 01-12-2003 | 03:22 AM
use great planes CG balance machine, it works!!
I always go for strait line, so a ruler is in order.
Old 01-12-2003 | 08:25 AM
8KCABrett's Avatar
Default Thanks!!
Well that explains why its always been fine!! I never realized I wasn't sure until I built this particular plane. . . pretty funny I went this long without knowing. . .thanks!!!
Brett
Maiden flight of the ultimate in the morning. . . I am excited!!
Old 01-12-2003 | 08:48 AM
Banned
The flexible tape wil place the CG SLIGHTLY forward of where you intended. Usually less than 1/8 inch difference.
Since a sligtly forward CG is rarely (practically NEVER) gong to destroy a model... its not a problem.
Remember... Nose-heavy = slugginsh performance. Tail-heavy = broken airplane. Its easier to fix noseheavy's result after landing than tailheavy's result after impact
