 Why are you doing this to me!!?? >
Old 10-21-2006 | 04:25 AM
Default Why are you doing this to me!!??
when i turn my planes battery on after the transmitter (like your meant to.) My rudder glitches quit a bit.
can anyone tell me why my rudder is doing it and how to fix it. This is the first time its happened.
Old 10-21-2006 | 04:42 AM
My Feedback: (29)
Default RE: Why are you doing this to me!!??
Is your Transmitter on PCM and your plane not? I switch back and forth with a Heli that is set up on PCM and my planes are PPM. When switching you have to cycle power to the transmitter for it to take. I have been doing this all season and just last week my plane got the jitters. Took me by surprise for a moment and then it became obvious to me what was going on. Brain fade for amoment I guess.
Just a thought,
Peter
Old 10-21-2006 | 04:59 AM
how does it act when you step away from it?
Old 10-21-2006 | 05:30 AM
OK something very strange has just happened i started charging my plane and the battery wasn't too low but then i checked and it was glitching only a small amount and yes when i walk away it stops completely
Old 10-21-2006 | 05:34 AM
Wild Foamy's Avatar
my Savage starts glitching when the Reviever batts are very low
charge them up and try again
Old 10-21-2006 | 07:48 AM
i'd say the twitching is one of three things. low rx battery. low tx battery. tx too close to plane. even with the antenna down i've found that ALL my planes get the jitters when the tx is closer than 3 feet to the plane. some i've had to move to as far as 5 before it was still.
just my 0.02 worth
Old 10-21-2006 | 08:58 AM
If the batteries in both the TX and the airplane are fully charged then the problem is the Tx is too close to the airplane. Do a range check and make sure everything is OK. I do one prior to the first flight of the day on each of my aircraft.
Regards,
doubledee
Old 10-21-2006 | 09:01 AM
Oh right yea my plane only jitters now when i have the tx like right next to the plane but its never jitter as much as it did today should i worry bout this i will do a range check to.
Old 10-21-2006 | 09:07 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
speedmistro,
As long as the radio passes a range check you don't have anything to worry about. As it was said above, your transmitter is too close to the receiver antenna. Let me guess, when you turn on the receiver and transmitter the transmitter is leaning on the plane?? Or right next to it??? What's happening is that the transmitter sitting that close to the receiver is simply "overpowering" the receiver and causing the twitching. As soon as you move a bit away it stops. Nothing to worry about as long as the system range checks ok.
Hope this helps
Ken
Old 10-21-2006 | 10:18 AM
O right i done a radio check and everything seems ok thanks alot for the help.
Old 10-21-2006 | 10:41 AM
Missileman's Avatar
ORIGINAL: speedmistro
From this post I have to add don't turn your airplane on while charging from an AC source, the pulsing DC output will make your servos twitch.
Old 10-21-2006 | 11:03 AM
Oh right ill remember the issues here if i get the problem again thanks
Old 10-21-2006 | 01:16 PM
opjose's Avatar
What type of servos are involved?
