 Battery Switch >
Battery Switch
Battery Switch
Old 11-02-2006 | 10:35 AM
Default Battery Switch
Hey Guys, Newbie question!
New to electric flight, and i am building a 3D park flyer. My question is, do these type of setups with LiPo batts and ESC use a any kind of switch harness?
Thanks [8D]
Old 11-02-2006 | 10:41 AM
coolbean's Avatar
Default RE: Battery Switch
Not usually. Just turn on the TX, make sure the throttle is off and plug your battery into the ESC and treat the plane as if it has a running motor. SOME ESCs have a switch on them to turn them on and off.. but that switch is kind of misleading. It does disarm the motor and stops powering the receiver, but it still draws some power. You can't leave your battery plugged into it with the switch off overnight or your battery will be dead by morning.
