 Commander II nose dives! >
Old 11-05-2006 | 09:31 AM
Default Commander II nose dives!
Took out my commander II this morning. It did not climb very well and nose dived more times than I care to admit. There is trailing edge damage from the propeller and the foam separator is dislodged in the firewall so the motor is no longer stationary. I will fix these things and try again but I do not know why the plane would not climb. The tail flaps look OK (the only thing not damaged). Any ideas?
Jazieyone
Old 11-05-2006 | 11:07 AM
Wild Foamy's Avatar
Default RE: Commander II nose dives!
if your adding glue and stuff it may move the balance and add weight e.t.c
Old 11-05-2006 | 11:38 AM
hogflyer's Avatar
jazieyone
Three quick and easy things to check for:
Check the CG - diving is a sign of being very nose heavy.
Check the angle of incidence of the wing to the stab - the the trailing edge of the wing higher that it should be?
Check the thrust line to make sure it's not pushing the nose down excessively.
Hogflyer
Old 11-05-2006 | 12:18 PM
B.L.E.'s Avatar
Make sure you are not overcontrolling it and making it go into a spiral dive.
