Flying in the Wind
Here's a friendly reminder for those of you who forgot, or those of you who won't go out when the windsock isn't completely limp. Flying in the wind is fun! I was reminded of this fact again today. I am down in Illinois visiting my family this weekend and I brought my Twist on skis. This plane is really light, but is a blast to fly in the wind. I was having a ball just hovering (horizontal, not vertical) in about a 20 knot wind. Then trying the same thing inverted. I had it flying backwards at one point. Landings were completely vertical.
Do yourself a favor and don't put the planes away when the wind blows. You'll be a better pilot and have a lot of fun.
-Scott
-Scott
WY
Ken, its the same way here. Dont want to fly in wind? then you arent going to fly.
But like Scott said, flying the the wind is a blast. A few flights after I solo'd, the wind picked up on me pretty good, so I decided to play around, and just see what happened. I was actually out there dancing around because I was having so much fun. My trainer usually didnt do anything interresting. But in the wind, it was doing all kinds of stuff. It was great!
trey
trey
Hayden-
You raise a good point. No, a small electric like a Firebird would not be much fun in the wind. You have to have enough power to actually overcome the wind. My Twist has a Saito .80 in it, so I do most of my flying at 1/4 throttle or less, even in the wind.
-Scott
-Scott
ORIGINAL: hayden07
yes i suppose your right is there a way i could make it more poerfull
The short answer is no. The long answer is still no. I'm not a Firebird expert, but I believe a Firebird is a two-channel plane that controls altitude by motor rpm rather than an elevator. A plane like this is always going to be a poor performer in the wind. As motor rpm increases, the plane will climb. If you were somehow able to increase rpms by modifying the motor/battery combo, you will only increase the plane's tendency to climb. No matter what you do to the plane, this plane would always be tossed about in the wind.
Maybe a Firebird owner will correct me if I'm wrong. Otherwise, have fun with it, but stick to the calm days.
-Scott
Get a more advanced electric and you can fly on a windy day. I have flown a Mini Ultra Stik on days when I had to keep the motor running after landing so the wind wouldn't blow it backwards on the runway.
