 newbie TE/hinging question >
Old 12-10-2006 | 09:54 PM
iraqvet's Avatar
Default newbie TE/hinging question
It's been 13 years since my last kit build and I'm about finished with the wing on my 4*60. The instructions say to sand the LE edge of the ailerons but doesn't this come after the hinge slots are cut?
Old 12-10-2006 | 10:06 PM
Rcpilot's Avatar
My Feedback: (78)
Default RE: newbie TE/hinging question
Yeah, you can do it that way. I think it's actually easier to cut the hinge slots in them before you sand the bevel.
Draw a centerline down the LE of the ailerons. Cut the slots for your CA hinges or DuBro flat pinned hinges. Or, if your using Robarts, drill your holes and get the countersink to the right depth for a good fit.
When your done with cutting the hinge slots or drilling the holes, sand down to the line you drew on the centerline. Done. Now mock up your control horns and make sure they solid and mounted where you need them. Remove the control horns.
You can sand the TE of the ailerons if you want. I always just left them the stock thickness.
Your ready to cover the ailerons now.
