 hooby people power pannel >
Old 12-26-2006 | 01:53 PM
Jose R.'s Avatar
Default hooby people power pannel
hello, I got an alredy built global box with a hobby people power pannel. I dont know where to charge it. am I soposed to charge it on the starter jacks?
Old 12-26-2006 | 01:56 PM
Default RE: hooby people power pannel
That's where I charge my Hobbico battery.
Old 12-26-2006 | 02:10 PM
My Feedback: (85)
ORIGINAL: eagles9239
Yes
Old 12-26-2006 | 03:40 PM
Jose R.'s Avatar
also the LED light on the charger dosent turn on. Is that OK?
Old 12-26-2006 | 04:54 PM
We're talking about the charger for the field box battery?
1. is the battery there and connected properly?
2. Is it a 12 volt charger?
3. LED will ONLY light when connected to battery and in correct polarity (supposedly).[:@]
4. Even if battery is poor condition the LED SHOULD come on, unless it is defective.
Old 12-26-2006 | 08:33 PM
Jose R.'s Avatar
yeah the battrey is connected properly & everything works.Only the DC Ampmeter dosent work. Its a wall charger. here is the model I am using: http://www.hobbypeople.net/gallery/350280.asp
here is the charger: http://www.hobbypeople.net/gallery/110270.asp
and the battery: http://www.hobbypeople.net/gallery/110171.asp
Old 12-26-2006 | 11:13 PM
The ammeter is for showing how much current is flowing OUT to the glow plug. That is the ONLY time you should see a reading on it.
The LCD on the charger (no mention of one in the website though) should only be on when the charger is attached to the battery. If measured with a meter it (the charger) should have an output ABOVE 12 volts when NOT attached to the battery. How much above varies from charger to charger so I won't give an exact number here but I think I'd expect at least 14 volts without a load. It's possible that you have a defective component.
Old 12-26-2006 | 11:15 PM
Jose R.'s Avatar
so I should replace the charger, or take the whole thing in tommarow & have them check it?
