Telemaster
Hey,
I want to modify my Mini Telemaster plans so the it has ailerons.
How much diherdal should it have?
How big should the ailerons be?
Should any other part of the aircraft be modified so that the ailerons are more effective?
Any photos of Mini Telemasters with ailerons would be great!!!
Cheers
Cheers
AL
I just recently scratch built another mini telemaster and this time I did the same thing by adding ailerons. I cut the dihedral in half and basically made full span balsa strip ailerons. I have yet to fly the plane, some construction still left but I don't see why it wouldn't work. I also put one servo in each wing but you can get by with using just one servo in the center. Good luck!
My Feedback: (16)
GA
I would recommend only 2 degree of Dihedral for this wing.
ORIGINAL: gosk8ing
Hey,
Cheers
Hey,
Cheers
