help is needed >
help is needed
help is needed
Old 02-01-2003 | 02:18 PM
Default help is needed
I need some serious help, My plane keeps stalling when i give it gas, i have checked the carb numerous of times and done plenty of checks for leaks in the fuel line, what can this be? If someone can also help with how to keep this brand new .90 engine started please help. I have to pour gas into the carb to get it running.
Old 02-01-2003 | 02:23 PM
please provide more infos, engine type, exact symptoms, propeller etc......
Old 02-01-2003 | 02:36 PM
Youre needle valve could be set to rich, get someone to set reset it again. You can use a tachometer to make sure you get the perfect setting. Always set it slightly rich.
Old 02-01-2003 | 02:47 PM
Generally, if an engine stalls when you advance the throttle, the problem is that the low speed mixture is too rich.
To test this, with the motor idling, pinch the fuel supply line. If the motor speeds up and then dies, lean out the low speed needle or open up the airbleed screw.
It really would help to know the make and model of the engine.
