 Prop Rotation >
Prop Rotation
Prop Rotation
Old 02-04-2007 | 11:53 AM
bretzi's Avatar
Default Prop Rotation
Hi all,
I am new to this hobby and just wondering wich way the prop has to rotate when you start the engine? Clockwise ?
Thanks, Ralf
Old 02-04-2007 | 12:00 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Prop Rotation
Looking at prop from in front of the plane it should rotate counter-clockwise.
Ken
Old 02-04-2007 | 12:07 PM
bretzi's Avatar
Thanks Ken
Old 02-04-2007 | 12:37 PM
Just a suplement to Ken's comment. It is possible for a two stroke motor to start backwards since there is no valve train. This seems to happen more on cold days. It is not easy to see if this has occurred, but if you stand behind the motor and don't feel air blowing at you shut it down and try again.
Old 02-04-2007 | 12:44 PM
RCKen's Avatar
My Feedback: (9)
The biggest reason a 2-stroke will run backwards is trying to start a flooded engine.
4-stroke engines with valves can and do run backwards also.
Ken
Old 02-04-2007 | 01:40 PM
When hand-starting, a couple of my two-strokes will regularly start backwards. I'm one of those ludites who starts by flipping through the compression, rather than against it. Usually with a blip or two of the throttle one of them will flip around, but the other generally requires me to shut it down. There's nothing unusual about a two-stroke starting up backwards.
If you're using a starter, however, that should never happen.
