Dihedral braces ?? >
Dihedral braces ??
Dihedral braces ??
Old 02-06-2003 | 09:29 AM
C 130's Avatar
Default Dihedral braces ??
hello guys
am pretty new to this business and i have a question,
What is really the job of the "Dihedral braces" used in wing assembly, is it only to provide an angle between the two wings???? why do we need an angle so ? if so what is the best angle to use ???
thanx alot guys : ) have a nice day
Old 02-06-2003 | 09:50 AM
The angle of dihedral will depend on the type of aircraft, the reason for it is that it provides natural stability.
Assuming you have a left and right hand wing panel, each will be strong enough because of it's internal structure, spars etc. the weak point is where they are joined to each other at the middle. The brace is to provide strength in this area which takes more load than any other part of the wing.
Simon.
Old 02-06-2003 | 06:04 PM
MinnFlyer's Avatar
The dihedral braces keep the wings from getting too much dihedral while in flight.
Without them, the two wings tend to increase their dihedral until they meet in a vertical line above the fusalage. Not a good thing to have happen.
