 yard dart >
yard dart
yard dart
Old 02-23-2007 | 07:08 PM
Default yard dart
Found out the meaning of yard dart, unfortunately the first day I got the plane. The plane was a Flyzone cessna 182 and was a poor choice for me, straight in the soft grass.
Question, what's another plane(trainer) that I can throw the electronics into and have another flyer. I don't want to replace the fuselage on the cessna, too squirly for me for I did fly it about 8 minutes. Preferably a foam or wood and possibly a slow stick. The electronics are tactic 4 channel radio, tactic receiver, 15a esc and 3 micro servos, and a 370 motor.
Old 02-23-2007 | 07:57 PM
CGRetired's Avatar
Default RE: yard dart
Have you solo'ed yet? Are you new to RC? If you are new, do you have an instructor to work with you? If not, then I highly recommend you find an instructor because you will find your bank account dwindle as you try to learn to fly by yourself.
DS.
Old 02-23-2007 | 08:03 PM
I've been flying the wings off a 3ch skyfly and was trying a 4ch supposedly trainer. I do have an instructor thats going to help me fly my alpha 40 this spring.
How about this plane except it recommends a 20amp esc and mine is 15amp.
http://www2.towerhobbies.com/cgi-bin...&I=LXHCL2&P=ML
Old 02-23-2007 | 08:46 PM
hogflyer's Avatar
johntammi,
I'd hold off getting a replacement for the EP park flyer for now. Wait until you start flying your Alpha with your instructor and you soon find you'll want something a bit more maneuverable for a park flyer. After you've gotten comfortable with the Alpha and learned some basic aerobatics you'll have a better idea of the kind of park flyer that would best suite you.
Hogflyer
Old 02-23-2007 | 09:01 PM
I'd go with the GWS pico stick, the estarter is pretty fast...Rog
Old 02-23-2007 | 10:24 PM
No recommendation but if you do replace it, have an experienced pilot get the plane up to a safe altitude BEFORE you start flying it. Don't even think about landing it until you can fly it reliably at altitude. False pride will just run up the expenses.
Old 02-23-2007 | 10:57 PM
I'll stop here and keep flying the skyfly till flying starts at the club.
Old 02-24-2007 | 11:13 AM
Better yet, I ordered a supercub and should do alot better with it.
Old 02-24-2007 | 11:40 AM
Wild Foamy's Avatar
ive been looking at those supercubs... how good are those anti-crash sensors? (assuming this is the hobbyzone supercub)
Old 02-24-2007 | 12:02 PM
The anti crash is not very good. If you fly over water (and I assume snow cover would be the same) the unit goes wild and will guarantee a crash. In local experioence with two of them, both had to be disabled in order to fly the plane.
Old 02-24-2007 | 03:26 PM
If you have learned to fly a 3 channel aircraft you will need some help in learning to fly a 4 channel airplane. flying a four channel trainer is not too different from a 3 channel but if you remove some of the dihedral you will notice the difference and if you try to fly a mid wing pattern aircraft your reflexes for flying a 3 channel can prove fatal. I watched a fairly good pilot who could fly 3 channel well get flipped on his side by a gust of wind then he hit his rudder like always to level it out and all it did was point his nose up but he was still in knife edge till he hit the ground. You need an instructor until you can program your reflexes for 4 channel ops or you might have a few repairs coming
Old 02-24-2007 | 10:15 PM
I think the plane was too heavy for wing area, too small and very quick when using aileron.
I'm staying away from 4 channel til I learn to fly my alpha 40 with my instructor this spring.
