quick fueler for glow engine on cub >
Old 02-15-2003 | 01:53 AM
My Feedback: (17)
Default quick fueler for glow engine on cub
alright last post and i will stop bugging you people but this is a good place for info, well this is the way i have set it up from the fuel tank i have two hoses coming out one to my muffler then to the needle valve out the needle valve to my refueler from the refueler to the carb is this going to work or is there a differnt way of doing it thanks mike
Old 02-15-2003 | 02:36 AM
That will do just fine. just make sure the line coming from the muffler to the tank is the one hooked up to the vent tube on the top of the tank. I even managed to mix that up just last week on my newest spad.
Old 02-15-2003 | 04:02 AM
Default Re: quick fueler for glow engine on cub
Are you saying you have the refueler between the needle valve and the carb?!?! It could work, but would be slow since you are pushing the fuel past the needle valve while trying to fill the tank. The refueler should be between the tank and the needle valve.
