 Which props to which engines?? >
Old 03-26-2007 | 05:42 PM
Default Which props to which engines??
Hey!
Have two Enya 35 and one Enya 45, all without propellers.Is there a list of which props that fits which engines?? I realize of course that there are several props that fits one engine, depending on plane,type of flying, etc, but between thumb and forefinger as a general guidance??
Mikke
Old 03-26-2007 | 05:46 PM
Hydro Junkie's Avatar
Default RE: Which props to which engines??
I would look at a 10X6 for the .35 and probably a 11X5 for the .45
Old 03-26-2007 | 07:23 PM
While remembering this is just a guide to get you in the ballpark
http://www.top-flite.com/accys/topq5000a.html
Old 03-26-2007 | 07:31 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Mikke,
See if this helps you out any.
Hope this helps
Ken
Old 03-26-2007 | 07:45 PM
That makes me feel good to see my recommendations were close, especially since I was going from memory[8D]
Old 03-26-2007 | 09:03 PM
downunder's Avatar
The Enya 35 will be an iron piston so it needs 25% all castor fuel. Run it on this fuel and it will never wear out. Almost literally! For RC use the Enya chart suggests 10x4 to 11x6. There are several versions of the 35 but only detail differences.
There were also several versions of the 45, two of them are baffled piston and a Schneurle ported 45X with AAC construction. The chart for the model 6001 (baffled piston, two rings) suggests 11x5 or 11x6. The model 6002 (baffled piston, single ring) suggests 10x5 to 11x6. The 45X suggests 10x4 to 11x7.
Old 03-27-2007 | 01:17 AM
Thank you all for your input !!
My 35 Enya´s are : 35 II,model 6001 and 35, model 5224.
The 45 is : CX.
Mikke
