Re: Plastic clevis pins >
Old 02-21-2003 | 04:36 AM
Default Re: Plastic clevis pins
Hi Gang,
I have the plastic clevis pins and horns on all my planes.
I was told to replace them because they are known to have many failures.
I was also told that some types of screw lock connectors can work loose no matter how tight you crank down on them.
Any suggestions are appreciated.
Old 02-21-2003 | 05:04 AM
My Feedback: (9)
You really opened up a can of worms now!! I use metal Sullivan Gold clevises & the screw locks on throttle only. Z bends on 60 size & down planes on servo arms. >>>>>big max 1935>>>>>>
Old 02-21-2003 | 05:28 AM
[i]big max 1935>>>>>> [/B]
Hi big max
Well I have the TH catalog here.
I ordered over $100.00 in needed items so far.
The list is getting longer but with 4 planes and another on the way plus another being built I can't be short.
DUBRO has the screw locks for $7,50 for 12.
Not bad.
I also ordered serews,Ball wrench set,glow plugs,*T* pins and much more.
What I don't like about the plastic pins is that they use that small rubber ring to hold the clevis closed.
Best not to chance crashing over a cheap $1.00 part.
Thanks for the post
Old 02-21-2003 | 06:19 AM
My Feedback: (9)
If you do use the SULLIVAN GOLD CONNECTORS get a package of extra lock clips, you will need them & they are cheap !MAX
Old 02-21-2003 | 03:36 PM
As far as your question about plastic clevis on the trainers you fly plastic clevis are fine just cut a small piece of fuel tubing and slip it over the end of the clevis to act as a lock.
Old 02-21-2003 | 05:18 PM
In many respects, the nylon pins are better than metal for safety and longivity. The metal pins wear much faster, I've acutally worn some in two over a couple years of use. The nylon wears much better. Now, there are some plastic clevises (not nylon) that are much weaker and I would not recommend them. If you stick to a well known manufacturer, you should have no problems. Just do as mentioned above, put a piece of fuel line around them to hold them together.
Old 02-22-2003 | 02:27 AM
Rodney is right. The plastic pins tend to be smoother. I always use plastic clevises or a screw on ball link on any type of metal arm to avoid metal to metal contact.
FYI - I've been flying R/C since the 70's, have used a lot of plastic clevises and have NEVER had one fail for any reason. However, I do inspect them periodically and replace worn clevises as needed. A lot of guys build the plane and never look at any of the connections again ever. That's just bad news.
One last tip. The night before you go flying, pre-pre-flight your plane at home and look it over good. What I do is give them a good cleaning so they gleam real nice and make me proud. While I'm cleaning I look at everything and then I'm not distracted by others like I am when I do a pre-flight at the field.
I can honestly say I've found a lot of things that needed to be fixed or adjusted that I may have over-looked at the field in the rush to get into the air. For me it's standard operating procedure now. I can't remember the last time I lost a plane due to equipment failure. I wish I could say the same thing about my piloting skills.
Old 02-22-2003 | 02:28 AM
PS. I've gotten some really cheap looking plastic clevises in kits. Those get discarded immediately. Dubro or Great Planes clevises are good brands and should give you no problems.
Old 02-22-2003 | 05:57 AM
My Feedback: (9)
Whirley Bird : See what I meant by "a can of worms". It all comes down to what is your choice & what you have least problems with.>>>>>>>>big max 1935>>>>>>>>>>>>
Old 02-23-2003 | 07:37 AM
Thanks for that TIP Crashman.
I was just looking through my O ring set I use for car A/C but concerned about them holding up against the fuel.
Good thing I thought of the fuel line HUH?
Old 02-23-2003 | 07:43 AM
Well big max I have a bad habit of doing that but it's fun
Sure did get a lot of input
