 Wing Tube Selection >
Wing Tube Selection
Wing Tube Selection
Old 05-06-2007 | 01:44 PM
Default Wing Tube Selection
I'm fairly new at constructing wings with wing tubes.
Does anyone have or know of a magic formula or standard for calculating wing thickness vs tube diameter - wing span vs tube length?
I've done some measurements on some of the planes that I and my freinds have and I'm guessing around 50% thickness and 30% to 40% of the span.
Thanks all...
Old 05-06-2007 | 07:32 PM
P-40 DRIVER's Avatar
Default RE: Wing Tube Selection
I would select the same size tube as a similar weight airplane carries or you could make up a jig and do 20G test on it, if it passes that, it should survive anything.
