 Heat Iron >
Heat Iron
Heat Iron
Old 05-21-2007 | 04:21 AM
mouthpiec's Avatar
Default Heat Iron
Hi,
What is the best temperature to set on the Heating Iron to apply covering?
thanks in advance
Old 05-21-2007 | 05:23 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Heat Iron
The tacking and shrinking temperature settings will depend on the type of covering you're using. Which type do you have?
Old 05-21-2007 | 05:29 AM
mouthpiec's Avatar
Hangar 9 UltraCote
Old 05-21-2007 | 05:41 AM
There are instructions which come with the covering materials that explain the proper temperature to use. I would strongly suggest you use these to determine the right temp. If you lost, or did not get these instructions at the time of purchase, go back to the hobby shop, go online and see if you can get them there.
After almost 40 years of being involved in this hobby I can never remember these important points and always refer to the instructions.
Old 05-21-2007 | 06:21 AM
rajul's Avatar
Moderator
My Feedback: (58)
Go to the service page and you'll find all you need to know about ultracote or oracover
http://www.oracover.biz/xml/frames.x...ml?node_id=392
Old 05-21-2007 | 08:03 AM
MinnFlyer's Avatar
Vary the temp and see what works best. Don't trust the temp on the iron. I don't even trust those thermometers
