 tail wheel. >
tail wheel.
tail wheel.
Old 05-26-2007 | 04:34 PM
Default tail wheel.
I have a 60 size super chipmunk and I missed getting to the hobby shop and hardley no hard wood. will a circular control horn work as a tail wheel or no, any other suggestions for an improvising.
Thanks, dave trimmer
Old 05-26-2007 | 04:57 PM
Big feet's Avatar
Default RE: tail wheel.
Hi Dave,
As a short term measure? Is this just to get you in the air over the weekend?
If so you colud give it a go, just try to land on the main gear, ie slightly faster that normal, so you don't put any landing impact on the tail err wheel.
You could simply use a wire bent backwards, like the old WW1 biplanes, for a quick fix.
Have fun.
Old 05-26-2007 | 05:12 PM
I forgot about using a skid, I'll do that, thanks
Old 05-27-2007 | 08:44 AM
If you are flying off grass, you may find the tail skid much better than a tail wheel.
Old 05-27-2007 | 04:21 PM
acarter's Avatar
i fly off light grass and my wire tail skid (extra control rod) works great, it doesn't steer at low speeds, but niehter woudl a tailwheel in the grass
Old 05-27-2007 | 05:07 PM
ORIGINAL: acarter
Actually, tailwheels steer great in grass. Any kind and height of grass.
