 2 blade to 3blade prop >
Old 06-04-2007 | 08:14 AM
Default 2 blade to 3blade prop
Hi I have a OS.65LA using a 12x8 prop and want to switch to a 3blade prop where or what size prop could be used and is there a conversion chart for prop swap with engines size thank's Frank
Old 06-04-2007 | 08:38 AM
Default RE: 2 blade to 3blade prop
Although not perfect, the general rule of thumb is to go down one inch in pitch or diameter. If you use a 12x8 two blade, try an 11x8 or 12x7 three blade prop.
Old 06-04-2007 | 10:52 AM
You maybe correct Jim. I was told down 1 in in dia up 1 deg in pitch so a 12x8 2 blade would be a 11x9 3 blade. I don't know for sure that's what i was told
Old 06-04-2007 | 11:47 AM
I changed a 14x8 to a 13x7 MAS on a 90 4S, works great.
Old 06-04-2007 | 07:09 PM
Thank's Jim Jet and scratchonly I wrote to OS but they haven't reply in two days guess best thng to do is try one of each size down and one with the pitch down too ...[8D] see how she act's Frank
Old 06-04-2007 | 07:49 PM
For what it is worth (and its not much) here are RPMs on a Magnum 61 four stroke comparing 2 and 3 blade props.
Test was done using 15% fuel, both props tested on the same day, thrust measured with digital fish scale, RPM are sustained (not peak).
Master Airscrew Scimitar 2-blade 12x6 10k RPM 5lb 5oz thrust.
Master Airscrew 3-blade 10x7 10500 RPM 4lb 12oz thrust.
Old 06-04-2007 | 07:57 PM
oceansfiftyseven's Avatar
I have not tried to replace a 12x8 but here are some conversions I have used:
10x4 2 blade= 8x6 3 blade
11x6 2 blade= 9x7 3 blade
12x6 2 blade= 11x7 3 blade
The 11x7 3 blade loaded more than the 12x6. Maybe the 11x7 would work for you?
carrellh's Avatar
Using “Prop Selector,” a 12x6 three blade should load an engine about the same as a 12x8 two blade.
If you’re wanting to change because you need additional ground clearance, an 11x7 three blade would load the engine slightly less than your current prop; and an 11x8 would load it slightly more.
Sometimes I think prop selection is voodoo or something. You buy every size imaginable. You try a bunch, and only like a few. Then you go back to the one you originally started with.
Old 06-07-2007 | 03:21 PM
The more accurate rule of thumb is "down one pitch AND diameter for every extra blade." It's worked just perfectly well for everyone I know, and didn't really reduce performance much at all. 4-stroke engines may be different, due to more torque...but that's the way 2-strokers work!
