 Top Flight prop balancer >
Old 06-07-2007 | 01:46 PM
Default Top Flight prop balancer
I was given a Top Flight Prop Balancer,
The two tapered pieces that go in the prop are missing.
Can any of you folks tell me what the angle or taper is on those parts?
I have a metal lathe and can make new ones if I knew what I am shooting for.
Thanks in advance.
I realize a new one is only$20 but it would be nice to get this one going again.
D
Old 06-07-2007 | 02:09 PM
MinnFlyer's Avatar
Default RE: Top Flight prop balancer
It's not critical, but it's about a 30º angle
Old 06-07-2007 | 02:19 PM
Thanks MinnFlyer,
what holds the two tapered bushings into the prop?
do they just push in and that is it?
D
Old 06-07-2007 | 02:24 PM
MinnFlyer's Avatar
They have an O-Ring that helps keep them snug
Old 06-07-2007 | 02:28 PM
Outstanding Minn
I should have figured it was something simple like that!
Thanks again!
Dee
Old 06-12-2007 | 03:18 PM
ORIGINAL: D12038
Outstanding Minn
Thanks again!
Dee
simpler than you think...............you can buy them for cheap right here...
http://www2.towerhobbies.com/cgi-bin...?&I=LXHY63&P=0
as MinnFlyer explained, they have an O-ring in them which is why i bought a few of them for back up.
i have a High Point balancer and couldn't find one of these to replace the one that wore out, and the TF cones work perfect.
i also like the TF balancer.........easy to setup and i don't have to be so careful in regards to dinging up the balancer wheels as i do on the High Point.
Old 06-12-2007 | 03:50 PM
MinnFlyer's Avatar
As a former machininst I can tell you that anyone with a metal lathe would rather DIE than buy a $2 item that he can make for under $30
Old 06-12-2007 | 04:42 PM
Hey Mike, any way to put some $30 bearings in them? Each side that is.
Old 06-13-2007 | 01:54 AM
troposcuba's Avatar
ORIGINAL: MinnFlyer
that's the truth! I find myself working on a "project" for 3 days that i could just buy for $10 at any hardware or hobby store. the wife thinks it's funny... well at least until i make her something that you can't really buy anywhere. then the jokes stop. But i think you could call this the fabricators disease or Jesse James syndrome or something like that.
Old 06-13-2007 | 06:10 AM
Mike is right, I don't do steel but I do woodworking and will spend more to make my own jigs. LOL, get ribbed from the wife also.
Bruce Aircraft percision bearings in the cradle I made my daughter. Wood was spalted birch. I could have bought this and the crib for 1/2 it cost me but.. I made it Bearings were about $25 ea LOL . We still have that cradle and the crib is on its 3rd owner and 4th child.
Old 06-13-2007 | 06:14 AM
CGRetired's Avatar
You just can't get that sort of quality at the store any more.. at least without paying through the nose for it, and even then, you won't get the same thing plus the satisfaction of having made it with your own hands.
Good job!!!
DS.
Old 06-13-2007 | 07:31 AM
Ah yes, the quality of a cradle made in Taiwan. [:'(]
Old 06-13-2007 | 09:59 AM
acarter's Avatar
now come on who buys that taiwan junk when you can get it made in china, LOL
Old 06-13-2007 | 11:44 AM
CGRetired's Avatar
Ah yes.. like my china made Goldberg Tiger 120. Real quality... [:'(]
Old 06-13-2007 | 11:51 AM
foosball_movie's Avatar
I have a Top Flight Balancer. It works great for props under 12 inches, but for longer props I find myself having to hold the two magnets in place after removing the support rods so the prop won't hit the table.
Is there a better way to use this device for larger props?
Old 06-13-2007 | 12:24 PM
Thanks DS on my build
foos, I have not used one so take this with a grain of salt but clothes pins on the shaft to hold the mags in place? Aligator clips?
