Set up
I have put together a b2 bomber but cannot get the electrics to work right.
I have 2 J perkins pro power 480 motors, GWS ICS 600 speed controller, GWS RX and TX
When I set it up the engines will run but I cant get the Y mixing to work. If I plug it stright into the RX the sevos work fine.
Any advise on this setup it worked fine with the first motors and speed controller but it burnt out when I changed the motors.
Pics of a set up welcome
Help
Mike
Help
Mike
Sorry about that V tail mixing I ment the say. Can any one suggest a type of setup its a foamex plane wing span about 1.2m made by walkera.
Mike
Mike
