 DuBro Spinner - Add Washer? >
Old 06-10-2007 | 08:03 PM
Default DuBro Spinner - Add Washer?
I really like the DuBro spinners, but the are recessed in the back where it meets the engine. This causes an issue when I try to put in on some of my models as the back plate will rub against the plane. Is there any reason that I can not put a washer between the back plate and the engine to space it out farther? Moving the engine forward is not a real good option for me at this time.
Rob
Old 06-10-2007 | 08:11 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: DuBro Spinner - Add Washer?
Nope, no reason at all. Go ahead and put a washer under there to move it out a little bit.
Ken
Old 06-10-2007 | 08:29 PM
thats good to know, i had the same issue when i put a 2 blade prop on my h-9 raptor
Old 06-10-2007 | 09:49 PM
Hey games, I had the same issue with my H9 Arrow and chose a slightly different route. Everyone at the field was mystified with the flywheel that comes with the PTS Evo engine. I chose to eliminate it altogether with the prop driver washer that comes with the Evo 46. Easiest $2.99 decision I made. The engine transitions to full throttle and back down again a bit quicker without all that extra weight on it.
Old 06-10-2007 | 10:43 PM
thanks man you got a link
Old 06-11-2007 | 11:40 AM
opjose's Avatar
ORIGINAL: rabraaten
It's there to make the idle more reliable and the tuning range a bit broader.
Old 06-11-2007 | 12:03 PM
carrellh's Avatar
ORIGINAL: gamesbeer1
It's probably this
http://www.horizonhobby.com/Products...odID=EVO040219
Old 06-11-2007 | 10:44 PM
I don't know if there is a difference but this is the one I bought.
http://www.horizonhobby.com/Products...odID=EVO100219
I knew that was what it was for but once the engine is well broken in and tuned right it is kinda redundant.
