Wiring for Field Box
My Feedback: (17)
I have a Hobbico Field Box with a 12V battery and Hobbico Accu-Glo Power Supply. I need some help in regards to wiring. Can I run the wires from the Powers supply to the battery and then run wire from the battery to banana plugs on the side of the box to use for the exteral wall charger? Will this mess up the power supply if they are soldered together on the battery? This may sound dumb but I just don't want to burn up anything.
My Feedback: (12)
SC
RE: Wiring for Field Box
Look at the back of the power panel. If it's like most others you'll see that the 12V sockets for the starter are connected directly to the battery leads. Rather than wiring a separate set of sockets for charging, I plug the charger into these starter sockets.
My Feedback: (27)
WI
Same here...
Now what I'm looking for is a wiring diagram to connect 2 x 12v batteries in series to run my 24v starter, but still allow me to operate a 12v power panel and also charge both batteries in parallel with my 12v charger??? I know that there must be some way to put a switch in to toggle between 12v in parallel and 24v in series - I just haven't been able to figure out what kind of switch and how to connect it.
TX
To get 24 Volt:
Battery 1 - Negative to negative binding post or bannana plug
Battery 1 - Positive to Battery 2 Negative
Battery 2 - Positive to positive binding post or bannana plug
To get 12V on same battery that has the two connected,
Battery 1 positive to the positive power panel and battery 1 negative to the power panel
Battery 2 positive to the positive power panel and battery 1 negative to the power panel
Battery 1 positive to battery 2 positive to power panel positive and battery 1 negative to battery 2 negative to power panel negative. (This will give you double the amp hours at 12v compaired to just one battery).
All this can be done on the same batteries to get both 12 volts and 24 volts from the same battery bank.
Try to put a fuse into the wiring if the battery is not readily accesible in case you have a short then the fuse will blow instead of the wiring burining up and starting a fire.
My Feedback: (12)
SC
ORIGINAL: danny31292
Thats gonna be a heck of a starter at 24 volts. A 12 volt motorcycle battery is enough power for me and has a lot more power that a field box battery.
PA
ORIGINAL: JustDreamin
My Feedback: (27)
WI
ORIGINAL: piper_chuck
I use 24 volts for my boat engines. In addition to having a few that 12 volts just won't turn over, 24 volts results in much quicker starts even for the ones where 12 volts was enough.
My Feedback: (12)
SC
ORIGINAL: krossk
I use a Sullivan Dynatron that works on both 12 and 24 volts. 12 is fine for my smaller engines, but I think I'll need a bit more for a 1.50-4C.
I drew up a diagram to allow 12 and 24 volts without a switch. This is something I need to wire up eventually, so it was worth spending a few minutes on. While this doesn't allow charging both batteries at the same time, I like being able to monitor the state of each battery.
I know it could be done with just one black jack off of battery 2. It also could be done with just two sets of jacks, using the left most + and the right most - would give 24 volts, but for simplicity of operation I thought having dedicated sets of 12 and 24 volt jacks made sense. What do you think?
My Feedback: (27)
WI
It looks like you've effectively accomplished with jacks what the DPDT switch in my drawing accomplishes.
By having 2 sets of jacks, you could implement the switch with jumpers.
1+ to 2- = 24V using 1- and 2+
1+ to 2+ and 1- to 2- = 12V parallel
BTW - My Dynatron is left over from my boating days as well. Nothing else even comes close for marine engines!
krossk - your drawing doesn't have "connection indicator" dots so I can't be absolutely sure where you are trying to make connections and where wires simply cross each other in your drawing. One thing I can say though is that you will NEVER get 24 v out of your present drawing in post #6. The MOST that drawing does is parallel the 2 batteries for high amp 12 volt service.
EDIT: Oh, I see what you are trying to do now. Again your lack of connection indicators confused me. Your red and black balls are supposed to represent UNLABLED jacks. And you had me assuming wrongly that you were trying to get 24 volts to the power panel. Tsk-tsk, poor drafting.
My Feedback: (27)
WI
There are no "overpasses" - anything that intersects is a connection.
The attached pic shows 24V when the switch is moved to the position represented by the purple lines.
ORIGINAL: krossk
My Feedback: (27)
WI
ORIGINAL: bruce88123
Besides, I haven't found a smoke-powered panel that doesn't leak on 24V!
I just wanted to avoid needing a separate charger or twice as long to charge it, but still have 24V available for larger engines.
