nexstar RTF,, noob here,,
ok,, well i guess this will be ideal for me,, i am a begginer in rc airplanes,, so i wanna start off with this one,,
although i have i problem, i dont have nitro fuel avaliable where i live,, but i can easily make my own fuel without nitro,, using methanol and high quality castor based synthetic racing oil,,
i use my mix to run my trucks,, and they dont like it very much, but i hear RC airplanes are netter at running on 0% nitro,,
so will the stock engine on the nexstar RTF work well on 0% nitro??????????????,, i am a beginner so i dont need all that performance
and what are the oil to methanol ratios in theese engines,,my normal mix for my trucks are 15% oil and the rest methanol,, can someone give me a gud fuel ratio for thees airplane engines,
http://www.towerhobbies.com/products...co/hcaa17.html
thanks
thanks
What you are trying to make is called FAI fuel.
You can Google it for various vendors.
Look at the FAI info at this site http://www.cooperfuels.com/airfuel_2.htm it gives percentages which are in line with what the guys have been telling you.
My Feedback: (13)
the OS fxi will run on no or low nitro fuel your oil needs to be at least 18%-20% you would be better having at least 5% nitro but if you cant get it then you can run the FAI fuel.
tuning is a bit touchy and more sensitive the less nitro you run in the engine.
Hi Dil:
What is the altitude (meters above sea level) that you fly at?
If you are at low altitudes (less than 500 masl) 0% nitro is fine for the engine that is supplied with the plane
If you're higher you either need to put 5 to 10% nitro or buy a bigger engine to compensate.
swampflier....
i am at sea level,, i live in sri lanka,, so its basically sea all around us,, except for the mountains,, but i live in the main city,, which is by the side of the sea,
so i am at sea level,,, and yayyyyy,, that means i am getting lucky finally.. had loads of problems wth the trucks,, sinnce they hate running on 0% nitro,, the engines stall alot,, but i use high quality ingredients,, so i guess it was the lack of nitro in my truck engines that gave trouble,,
well seems like the planes are better at running without nitro!!! finally i can have some fun,,, lotta learning to do before that though
thanks for the input guys!!!
