 Wing loading ? >
Wing loading ?
Wing loading ?
Old 06-22-2007 | 04:47 PM
Gary L.'s Avatar
Default Wing loading ?
I know I have seen it here some where, but caint find it. How do you get the wing loading , what times what ?
Thanks.
Old 06-22-2007 | 06:04 PM
Default RE: Wing loading ?
In our models it's often described in ounces/sq foot.
Take the area of the wing in square inches and divide that by 144. You now have the area of the model in square feet.
Take the weight of the airplane in ounces.
Divide the weight by the area.
The Fling 2M glider reviewed recently in R/C Report weighed 22.3 ounces. It's wing area was 477 sq.in. which would be 3.3 sq.ft.
22.3 / 3.3 = 6.75 oz/sq.ft.
Old 06-22-2007 | 06:17 PM
Gary L.'s Avatar
Thanks Rock.
Old 06-23-2007 | 09:07 AM
Campy's Avatar
You can also go here and use the calculator.
http://www.csd.net/~cgadd/eflight/calcs_wingload.htm
Old 06-23-2007 | 11:52 AM
Cyclic_ Hardover's Avatar
ORIGINAL: da Rock
To give you a ballpark area, that 6.75 basically means its a "floater" obviously. My prop jets are on the 30's which means it drops like a brick when the power is cut off.
Old 06-23-2007 | 12:26 PM
B.L.E.'s Avatar
A low wing loading doesn't garrantee that your plane is a floater. See how far an electric foamy indoor plane glides without power. On the other hand, sailplanes can have surprisingly high wing loadings as long as the drag is low, permitting high speed flight without a lot of energy loss.
Old 06-23-2007 | 02:25 PM
Well yeh, if I let go of a paper airplane without a little bit of a toss, am I going to expect it to takeoff or fall to the ground. I'm just telling him the blunt difference between the two.
Old 06-23-2007 | 08:16 PM
Gary L.'s Avatar
Thanks guys, It was something I thought I could use in the future.
Old 06-23-2007 | 09:32 PM
Most bi-planes actually have fairly good wing loadings but glide like bricks dragging anchors. So much "frontal area" to create drag.
