 HOW TO remove coloring from landing gear?? >
Old 07-02-2007 | 12:53 PM
Default HOW TO remove coloring from landing gear??
HI again
How do you remove the coloring that sometimes appear on landing gear during manufacturing? Almost the entire bottom of my landing gear has blue coloring on it. What do you use to remove that?
Old 07-02-2007 | 01:02 PM
Default RE: HOW TO remove coloring from landing gear??
I don't have experience with landing gear yet, but just looking at the pic.... Wouldn't sanding with a medium grit sand paper rub that right out?
Old 07-02-2007 | 02:42 PM
krossk's Avatar
My Feedback: (27)
Try using alcohol or acetone - that just looks like layout die used to make the scribe marks visible.
Old 07-02-2007 | 04:15 PM
I agree with krossk...there is a product thats very dangerous to use, highly flammable, will absorb through the skin, and is an inhalation hazard. don't use it near any flame pilot lights etc...no smoking or you will die. called MEK if the blue will come off, this will do it.
dont worry the stuff hasn't killed me yet...its quite common in aviation maintenance and has recently been carried in Wal Mrt stores
Old 07-02-2007 | 06:34 PM
horace315's Avatar
My Feedback: (15)
you might try some type of metal polish that will work onaluminum,even valve lapping compound with 00 steel wool.
Old 07-02-2007 | 09:54 PM
just an abraisive would do it - i think as mentioned plain old steel wool would do a great job (with or without the lapping compound)
also, i like the way you've mounted the landing gear (rubberbands) i might incorporate it into a next build to add a bit more "crashability" to it
