Battery location?
KS
Hey Guys, I had to move my battery way back into the fuselage to balance the plane right....does it matter if the antenna goes right by it and out the back? I wouldn't think so but want to check.
It will not bother the antenna but; if you make a hard landing, be sure you put in lots of support for that heavy battery or it will destroy everything in front of it as it switches ends inside the fuselage.
