Battery question
NY
Hi All,
I would like to replace one of my four standard s3004 servos to a high torque servo s3305 and also replace the 600mh battery to a higher capacity battery. I am not sure what the current draw is from the s3305 servo therefore not sure what size battery to use. Also any advice on the best type of battery to use would be great (Nicd, NimH, Lipo etc). This servo will be used in the rudder of a Goldberg Edge 540T ( 67").
Graham
Graham
IL
You could fly all day on a 1600mAh 6V pack. of course I don't recommend it, but you could.
I use a 5 cell NiMH sub C pack in my heli and it last a LONG time. A NiCd pack will give a stronger amp rating, but the NiMHs now a days are very good.
Nimh has more capacity but can't provide sustained high current draw (most servos are ok but big electric motors may be too much for an Nimh)
That said, I am running a 6 volt 2,000 mah Nimh made by Hobbico ($29 at Tower) on my 1/4 scale RV-4 and despite its 7 servos I can still fly all day with no sign of a low battery.
My Feedback: (12)
ORIGINAL: Missileman
ORIGINAL: piper_chuck
Ummm, I believe high current nimh batteries are available.
My Feedback: (12)
Thanks, I did not know that
NY
If i am using a 1600mAh Nicd battery on my futaba reciever with a three s3004 and one s3305 servo should I change the wire gage of my charge switch.
Graham
Graham
