 PC 9 with evolution 40 motor. >
Old 07-23-2007 | 07:00 AM
Default PC 9 with evolution 40 motor.
My dad aquired a PC-9 arf with a Evolution 40 motor ( mounted upside down) that was put together and were told it had been flown.
We went to run it and it would run for about a minute and then suddenly stop. The setup of the tank is a bit different as the fellow who installed it used the nipple above the stopper for the vent.??? and capped off 2 of the stopper lines.
Any thoughts. We were going to start by replacing the tank and see if that helps.
Del
Old 07-23-2007 | 10:46 AM
bigedmustafa's Avatar
Default RE: PC 9 with evolution 40 motor.
That particular tank setup actually sounds fine. A lot of Great Planes and/or Thunder Tiger fuel tanks come set up this way.
The more likely issue is the level of the tank stopper relative to the needle valve on the Evolution .40 engine. The needle valve needs to be at least as high as the centerline of the fuel tank or the engine will tend to syphon fuel and flood while it's idling.
You can play around with adjusting the tank height relative to the engine placement, but simply mounting the engine upright or at 90 degrees instead of inverted will most likely be the quickest way to happy flying.
