 HiTec Receiver Question >
Old 07-25-2007 | 09:36 AM
Indy Park Flyer's Avatar
Default HiTec Receiver Question
I just bought a Hangar 9 Pulse XT from a club member and he included a HiTec receiver. I use JR for my TX. Should I buy a JR or HiTec receiver crystal?
Indy Park Flyer
Old 07-25-2007 | 09:41 AM
-pkh-'s Avatar
Default RE: HiTec Receiver Question
Hitec equipment is typically negative shift... although they do make positive shift and auto shift receivers for use with JR and Airtronics. Unless your receiver is labelled "positive shift", "selectable shift", or "auto shift", you probably need to get a new receiver.
What model receiver is it?
Old 07-25-2007 | 09:45 AM
I don't have the receiver with me so I don't have the model number, but I know he has used this same reciever with his JR TX in the past, so I know it is compatible.
Indy Park Flyer
Old 07-25-2007 | 10:01 AM
-pkh-'s Avatar
If that's the case, then just get the Hitec crystal for your channel #. JR crystals may not work in Hitec receivers (usually best to stick with the same brand receiver xtal).
