 Overheating with muffler deflector >
Old 07-28-2007 | 03:45 PM
plugin's Avatar
Default Overheating with muffler deflector
I installed a silicone deflector today on my O.S .46 AX. I noticed that the engine was somewhat hotter than it used to be when it didn't use the deflector. Is this normal? Should I expect this to hamper the engine's performance or lifespan?
Old 07-28-2007 | 03:53 PM
Nathan King's Avatar
Default RE: Overheating with muffler deflector
The engine should not run noticeably different with the exhaust deflector. Are you sure the engine is not running too lean? Were the temperature/humidity levels considerably different on the two days?
Old 07-28-2007 | 03:58 PM
This can happen if the ID of the restrictor is to small, use a larger diameter deflector.
Old 07-28-2007 | 04:53 PM
Using a deflector like this
http://www2.towerhobbies.com/cgi-bin...?&I=LXL378&P=7
should NOT cause any problem if properly installed. Don't let it pinch off any due to the install and don't install a homemade one that is too small in diameter.
Old 07-28-2007 | 06:18 PM
Missileman's Avatar
I use the same ones that Bruce does and have never had a problem.
You may need to readjust your high end needle a bit because of slightly more backpressure.
Old 07-28-2007 | 06:53 PM
plugin's Avatar
Needle was readjusted and just to be certain I opened it about 1/4 of a turn when I noticed this, but it didnt change significantly. The engine used to com back from a flight really hot but it didn't boil water as it didn't fizz when I touched it with a wet finger, now t does.
Old 07-28-2007 | 07:14 PM
It sounds like you were already running too lean and still are. Just shouldn't be THAT hot.
Old 07-28-2007 | 07:39 PM
yep you have been running lean, the weather conditions changed and you're even leaner now. remember what ever you have set on the ground you will lean out a tad bit more in the air....you want to see a bit of exhaust in the air
Old 07-28-2007 | 09:12 PM
plugin's Avatar
I always get a smoke trail, so it suggests that im not leaned out. Why would you suppose that I was already running lean?
Old 07-29-2007 | 01:25 AM
My Feedback: (13)
you can be running lean and still get smoke out the pipe, that little pipe extension shouldn't make that much difference unless it's smaller than the muffler exit tube,the exit should be larger so as not to restrict exhaust flow.
Old 07-29-2007 | 06:16 AM
CGRetired's Avatar
Use the pinch test to set the mixture. Go to full throttle, and once it settles out, qiuckly pinch the fuel feed to the carb. If the engine note changes to slightly increase in RPM, then the fuel mixture is right. If it dies out, it is to lean, so adjust it out more (more fuel, richer mixture). Once you hear that slight increase in the rpm sound, then it should be alright.
I use a 90 size exhaust deflector on my three OS 1.20 AX's with no noticeable increase in engine temp at all. And, I use deflectors on my .46 as well as my .50 with no noticeable change in temp. So, it must be to lean.
Old 07-29-2007 | 07:52 AM
plugin's Avatar
Yeah this engine is set with the pinch test. Im positive its not running too rich, I just want to rule out the possibility that the heating is due to the darn deflector.
Old 07-29-2007 | 08:47 AM
Then take the deflector off for a flight and do the test again.
Back to back testing is one way to improve the odds you're doing good testing. BTW, my 49AXs all come back too hot to touch, and I'm absolutely positive they're not running too lean. And all have lengths of silicone tubing on the mufflers, even on the Pitts mufflers. But no lengths are over 3".
Two cycle engines usually do not overheat when a 2" or 3" flexible hose is added to the muffler's outlet. The commercial ones have rougly the same inner diameter as the mufflers they fit. And the silicone tubing that fits the mufflers has almost exactly the same I.D.
Any two cycle can overheat with too long an extension, but the overheating comes from back pressures that're greater than the design expects. And that backpressure would create a loss of power, because it would be stopping the hot exhaust gasses from exiting the cylinder. And those backed up gasses would be inhibiting the incoming fresh charge. So you would see a reduction of the engine's power. It would show up clearly on a tachometer. And any experienced modeler would detect the loss of rpm without a tach.
If you're not detecting an obvious loss of rpm, the conditions for overheating aren't coming from an increase in backpressure, which is the only thing the extension could do to cause overheating.
Old 07-29-2007 | 09:39 AM
As I recall you are using 0% Nitro fuel. I think that also tends to run hotter.
Old 07-29-2007 | 09:48 AM
B.L.E.'s Avatar
ORIGINAL: plugin
A lean engine can sometimes make more smoke than a rich engine simply because the rich engine is not hot enough to turn the oil into smoke. Don't judge fuel mixture by a smoke trail.
Old 07-29-2007 | 08:08 PM
Are you using a stock muffler ???? ENJOY !!! RED
Old 07-29-2007 | 10:43 PM
plugin's Avatar
Yeah I'm using the powerbox muffler that comes with the engine.
Old 07-30-2007 | 06:39 AM
and how long is your deflector?
and have you noticed a drop in max rpm from the engine with that deflector?
Old 07-30-2007 | 06:41 AM
ORIGINAL: plugin
Take it off for one flight.
If the overheating goes away, it was caused by the darn deflector.
If it doesn't, you got some other problem.
Old 07-30-2007 | 09:52 AM
3dd's Avatar
3dd
deflectors cause too much backpressure and make the engine overheat.you will have to richen it up too much to overcome this,take it off
Old 07-30-2007 | 10:10 AM
"too much backpressure"
When backpressure becomes "too much" the engine will not be able to reach peak rpm. It will lose power. It's very simple to judge when the backpressure is too much.
Deflector's don't always produce too much. Short ones usually don't show any effects at all, other than keeping your model clean.
It takes two flights to test. It takes weeks to argue and where are you after all the time reading. Our hobby is kewl that we can find our own answers in about 10 minutes flying.
