Real beginners question
WA
Yes, I'm new to this if you can't tell after reading this question.
Could someone explain how a 4 channel radio works? They all have two sticks, but do they both go up, down, left, right? Meaning two channels per stick?
A mode two four or more channel transmitter (mode two is the most common in the US) will have on the right stick, elevator also known as pitch control and is the up and down movement. The right and left movement on that same stick will be your ailerons (roll control). The left Stick up and down movement is your throttle (up is full and down is idle) and on that same stick with left and right movement is your rudder control (Yaw control).
John
By the way there are single stick radios with four or more channels and called mode three. They are now uncommon but treasured by their users and the rudder is operated by a large rotating knob on top of the right hand stick which now operates three channels and the throttle is operated by a slide lever on the side of the radio.
John
Hmmm...
After firebird ii, I am looking at firemoth or the slowstick pro.
WIll the planes have rudder, evelation, yaw, etc?
If not, I'd rather buy another trainer plane with those so i can learn.
There are a couple of articles on my web page that will benefit you. One is "Beginner's Guide to R/C Flight". It shows details of the transmitter and the effect that the stick movement has on the model. The other is "Radio Control System Operation". This one goes into the radio theory that is used to make the system operate but is done in layman's terms.
I added your page to my favorite list!
I also love the verse!!
(my favorite on a windy day is,.. "be still and KNOW that I am God"- in Psalms) Approtiate I think for a beginner?
Lance
edited:: i noticed you recommended gas planes as starters- do you have any recommendations for elec planes?
I didn't see this mentioned. The right joystick self centers. The left joystick centers from left to right, but "clicks" up and down. This allows you to set the throttle.
As for next electrics, there are a group of electrics which they consider "aileron trainers". This is mostly since most electric pilots start without ailerons and many move up to ailerons. In gas, you are more likely to start out (with an instructor) and with a plane with ailerons.
Two that seem to fit this bill are the Switchback (Mountain Models) and the Grumbler (don't remember the manufacturer).
I've seen reviews on both, but haven't actually flown them.
(snipped)
(snipped)
(one other plane i heard of was sig kadet lt-40? is this an elec plane?)
THANKS!!!
For everything you ever wanted to know a e-flight look at ezonemag.com
sig kadet lt-40 is not elec but can be converted.
great planes makes an electric verision of their PT-19 trainer
Just bought my son a Hobbico SuperStar Select Trainer 40 for Christmas. Everyone at the club said this is the best trainer on the market. It came with an OS40LA engine, 4 channel Futaba, all electronics mounted in this RTF. Super nice plane. Would recommend highly WS 60" & fuse 50" price was $299.99
Tim
Tim
Now if your an Ozzie
You will come accross mode 1.
right stick is throttle up and down and aeilrons side to side.
Left stick is rudder side to side and elevator up and down.
just to confuse you a little more.
Prboz
You will come accross mode 1.right stick is throttle up and down and aeilrons side to side.
Prboz
