 elevator direction >
elevator direction
elevator direction
Old 08-10-2007 | 02:07 PM
Default elevator direction
on my plane when i push my stick forward on my radio my elavators go up and when i pull back they go down now i think this is backward and if im right what do i need to do to make them right ?
Old 08-10-2007 | 02:11 PM
Default RE: elevator direction
Reverse switch on transmitter for each channel or move the pushrod to the other side of the servo.
Old 08-10-2007 | 02:21 PM
Missileman's Avatar
What kind of plane and radio and you will get more specific answer.
Yes it is backwards and most radios have a way of reversing the servo direction of that servo.
Old 08-10-2007 | 05:19 PM
Sounds like you would be WAY AHEAD if you got some help from a local club. ENJOY !!! RED
Old 08-10-2007 | 05:55 PM
If there is no reversing switch just put rhe linkage on the oppossite side of the servo.
Old 08-10-2007 | 06:09 PM
opjose's Avatar
Have you found any local clubs to help you out?
Old 08-10-2007 | 06:25 PM
daveopam's Avatar
My Feedback: (9)
PLEASE get some help. Or buy a few more for spares.
David
Old 08-10-2007 | 06:52 PM
If you plan to fly without an instructor, you really should grab your radio's instruction manual and read through it. You'll find things in there about reversing servo direction.
Everything that you find in that manual that makes little sense to you is basically something that will probably contribute to a problem you'll have. See a lot of things in there that don't make sense to you? See why we're advising you to seek out a club and find someone to fly with.
Old 08-10-2007 | 07:44 PM
This seems to answer the question in your other thread about why you couldn't keep your plane in the air.
OOPS.
Old 08-10-2007 | 09:02 PM
Cyclic Hardover's Avatar
Also answers a question about instructors. He'll give it up
