 Spinner question >
Spinner question
Spinner question
Old 09-01-2007 | 05:55 PM
Default Spinner question
Does a spinner hinder prop bite , i was thinking that the spinner does block part of the blade, and i was wondering if this would hinder performance ?
Old 09-01-2007 | 06:14 PM
chopper man's Avatar
Default RE: Spinner question
No
Old 09-01-2007 | 06:43 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
No.
Ken
Old 09-01-2007 | 07:58 PM
another no
And adding a spinner to a "naked" prop is one of the first things designers did back in the golder era of aviation to improve speed and range. And it improved speed and range.
Old 09-01-2007 | 08:10 PM
broke_n_bummin's Avatar
The power of the prop comed from the tips. As a matter of fact, it's said that a spinner can add RPMs by directing the airflow out toward the tips and away from the fuselage.
Old 09-01-2007 | 08:19 PM
Missileman's Avatar
Couple of things to think about.
Common sense really.
1. the inner part of the prop is moving much slower through the air than the outer portion so is less effective anyway.
2. the inner portion of the prop has an engine/airplane sitting directly behind it so if anything a tapered spinner will help break the air in front of this relativly flat surface and actually help improve performance of the aircraft overall.
Old 09-01-2007 | 08:35 PM
Still no.
Old 09-01-2007 | 09:27 PM
OzMo's Avatar
Also the nice pointy spinner helps to clear women and kids outta the way when carrying those birds to the car
Old 09-02-2007 | 07:27 AM
Actually, the speed of a prop does affect the efficiency of it. Generally speaking, slower is more efficient. And that applies all along the blade.
But in aerodynamics, it's not sound byte simple.
