 I Need Radio Help >
I Need Radio Help
I Need Radio Help
Old 09-05-2007 | 04:40 PM
chopper man's Avatar
Default I Need Radio Help
If I have a Hitec 6S mini receiver single conversion(?) and I put a #27 crystal in it, will it work with my Tower 6XM radio (freq is 27) I'm clueless[]
Thanks for your help.
chopper man
Old 09-05-2007 | 05:32 PM
Default RE: I Need Radio Help
ORIGINAL: chopper man
chopper man
The Tower TX is made by Futaba so it operates like one. The Hitec 6S is compatible with Futaba TX's. Now, as long as you used a correct Hitec single conversion crystal (or equivelent) you should be fine. A dual conversion crystal will NOT work.
Old 09-05-2007 | 05:54 PM
Missileman's Avatar
The Hitec 6s is an auto shift receiver and will work with any 72 Mhz FM transmitter as long as you have the hitec single conversion crystal in the right channel. Other brands of crystals may not work. I always buy the same brand crystal as the receiver I am putting it in.
Old 09-05-2007 | 06:03 PM
Thanks This is going to save me a bunch of money
chopper man
Old 09-05-2007 | 06:30 PM
http://www.hitecrcd.com/receivers/show?name=Mini-6S
