 Radio Help >
Radio Help
Radio Help
Old 09-05-2007 | 07:30 PM
Default Radio Help
I have a Futaba Fast 2.4 Ghz 6ch radio but it didn't come with a reciever batterie. How do I know what size (in volts) to use.
Thanks in advance
Electrolight
Old 09-05-2007 | 07:52 PM
tychoc's Avatar
Default RE: Radio Help
From their web site:
SPECS: Size: 1.6 x 1.1 x 0.35" (40 x 27 x 9mm)
Power Requirement: 4.8 - 6V
Current Drain: 80mA (at no signal)
Weight: 0.35oz (10g) with case
0.25oz (7g) without case
So, as most receivers, either 4.8 or 6 volt pack will work.
-tychoc
Old 09-05-2007 | 07:55 PM
acarter's Avatar
ORIGINAL: Electrolight
Thanks in advance
Electrolight
Your gonna love that radio!
Old 09-05-2007 | 08:39 PM
CGRetired's Avatar
Yeah.. I'll bet it's almost as good as a DX7!
Old 09-06-2007 | 12:41 PM
Alright thanks guys. I look foward to using it!
Electrolight
Old 09-06-2007 | 01:02 PM
You probably bought the version for Park Flyers(comes w/o battery pack) that gets power through the ESC/BEC thingy. (Not really my thing if you can't tell) If you are going to use in a plane with Nitro engine make sure you use correct size servos too.
Check carefully before proceeding. What servos di you have??
