 Servo Help >
Servo Help
Servo Help
Old 09-30-2007 | 02:34 PM
Default Servo Help
Great Planes Giant Super Chipmunk ARF .91-1.08, 81"
Servos: 7-Standard size servos with the following minimum torque rating:
1-throttle 30 oz-in
2-aileron 50 oz-in, 2-flaps 50 oz-in
1-elevator 50 oz-in, 1-rudder 80 oz-in
Could you suggest good servos for this plane?
Radio 7CAP Futaba
Old 09-30-2007 | 02:39 PM
dragnbye's Avatar
Default RE: Servo Help
any standerd servo should work beside the rudder you need a high touqe. i dont know fut servo as i fly jr but if you get towerhobies sale mag there i a nice chart of hitec and fut servo and there ratings. also if you swicth form 4.8 to .0 volts you can get a little more power out of your standerds
Old 09-30-2007 | 02:41 PM
OzMo's Avatar
Check out Tower hobby and servo city. any thing is OK for throttle but I would run higher torque on the other stuff, 6volt ( 5 cell)battery gives a little bost to servo function also. you might also ask this on one of the giant plane forums here.
Old 09-30-2007 | 02:44 PM
Thanks everyone
Old 09-30-2007 | 02:53 PM
Hitec Mighty Mini's are the hot tip for ailerons. Save over half an ounce each side. More torque than standards to boot. (55oz-in torque @ .9oz weight) Only about $21. They're the HS-225BB.
Any brand servos plug into Futaba RXs. It's Futaba servos that don't plug into anything else.
Look at HS-475KB for a standard for rudder or elevator. 60oz-in torque and composite gears (something like 5x stronger than regular nylon). About $16. or $17.
Old 09-30-2007 | 04:38 PM
goirish's Avatar
I just bought Hitec 475's for 14.95. Cheapest I have found. Obrienhobbies.com.
Old 09-30-2007 | 06:48 PM
acarter's Avatar
if you really wanna go above and beyond, tower hobbies is selling cs-140's with 82 torque on 6v for 18 bucks
Old 09-30-2007 | 07:59 PM
a65l's Avatar
My Feedback: (17)
Just a thought, but consider a metal gear servo on the rudder. Can save you a lost flying day if a nylon gear servo strips.
A
