 tail trouble >
tail trouble
tail trouble
Old 10-05-2007 | 03:42 PM
Default tail trouble
ok i just got the firebird phantom and crashed on the roof and relize oone of the flaps is not in line can any one help
Old 10-05-2007 | 04:13 PM
Default RE: tail trouble
everything is in tact just the rudder is outa wack i already tride trim
Old 10-05-2007 | 04:23 PM
seemefly_1's Avatar
try to fix the pushrod
Old 10-05-2007 | 04:34 PM
How
Old 10-05-2007 | 07:18 PM
RedGN's Avatar
There are two adjustment screws that hold the pushrods to the servo/rudder horns, You can loosen those off and set flaps straight then re-tighten them.
Hope that helps
Old 10-05-2007 | 09:58 PM
thanks alot i never thought it was that simple
Old 10-05-2007 | 11:26 PM
OzMo's Avatar
ORIGINAL: RedGN
Hope that helps
with the radio tx and rx on and trims to neutral to get as close to nuetral as posible.
