 Motor w/pinion >
Motor w/pinion
Motor w/pinion
Old 10-06-2007 | 07:45 PM
Default Motor w/pinion
Bought a new Parkzone 370 motor with pinion. However when i got home i noted the new one has 10 teeth, while my old one has 14 teeth.
Is it possible to pop that thing off and swap them? or do i have to go back to the store and exchange.
thanks.
jd
Old 10-06-2007 | 08:14 PM
Mr67Stang's Avatar
Default RE: Motor w/pinion
Yes, but you will end up buying a tool that cost more than that motor. You will need a gear puller to remove the pinions and and a vise to install the one you want.
Old 10-06-2007 | 09:28 PM
Missileman's Avatar
They are not that expensive and a handy tool to have around when messing with small gears:
http://www2.towerhobbies.com/cgi-bin...&I=LXHHN3&P=ML
Old 10-07-2007 | 10:10 AM
thanks for info.
