 This is a joke >
This is a joke
This is a joke
Old 10-08-2007 | 12:09 PM
Default This is a joke
I charged my NIMH battery last night for 3 hours. Went to bed, got up in the morning to fly the plane and the battery has no charge?
Is there like a 5 minute span you have to use the batteries? Seriously, nothing would work. Here i am charging it again for another 3 hours. This can't be right?
Thought i'd ask here. Want to know the truth before i go and get frustrated and its normal.
I mean, i use rechargable battereies for my RC cars and can use/run them for days. this makes no sense.
Old 10-08-2007 | 12:15 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: This is a joke
From looking at your previous post you said that the battery is only 800 Mah. That's a prettty small battery for an airplane. 5 minutes would sound just about right for a battery of that size.
Ken
Old 10-08-2007 | 12:16 PM
dragnbye's Avatar
i would see if you could feel a loose wire in the pack or see if someone at your field can try to cycle the pack if not your out of luck
Old 10-08-2007 | 12:20 PM
i charged it for 3 hours. let it sit overnight. i plugged it in initally last night and the propeller spun. i disconnected it, and went to bed. woke up and bam, battery dead. does the batteries drain from no use? and not weeks, but just 10 hours of no use?
Old 10-08-2007 | 01:08 PM
What kind of charger and charge rate did you use? IF this were a new NiCad and on a Wall-Wart charger this would be all that I would expect. If you used a fast charger that COULD be a different story. And YES, I did read that you are using NiMH, I was just doing a comparison. Unless using a fast charger, you are NOT going to fully charge a battery in 3 hours from a discharged condition.
Old 10-08-2007 | 01:51 PM
One more thing to check is to see if one of the cells "vented". I built a 2000mah pack for my transmitter and cycled it twice prior to flying the first time. It almost cost me a plane as the voltage dropped form 10.8 down to 8.8 in a maner of minutes, less than five. I my instructor hadn't been with me, it would have been a dead plane because I can't hear the beeper frequency on the transmitter.
Inspect the pack closely and maybe carefully cut the shrink wrap off to get a better look. Look for gunk around th positive end of the batterys and also look for bad spot weld joints on the tabs.
Don
Old 10-08-2007 | 04:29 PM
ORIGINAL: bruce88123
Which charger and battery pack would you recommend?
Old 10-08-2007 | 04:54 PM
I think you need to use what you already have but charge longer. Also make sure the batteries are OK condition. Also, from here, it's hard to tell what kind of plane you have which makes further recomendations hard.
Old 10-08-2007 | 05:42 PM
Missileman's Avatar
It is possible that you just plane got a junk battery.
I am sorry but I will be blunt. You bought a cheap throw away airplane. One thing in common with these are inconsistant quality.
I was in the same boat as you with one I bought when I first started out. The battery lasted all of one charge.
Try charging it again but you may end up contacting the company for a replacement.
UMM one last thing, are you sure it is the battery? The ESC on alot of electrics won't arm unless your throttle stick AND trim switch are both all the way to their lowest setting when you plug the battery in (safety feature)
Old 10-08-2007 | 08:03 PM
thanks for replies. this time around, the battery actually warmed to the touch, before it had never done that. perhaps finally breaking it in? not sure. anyway, in another post, i post a pic. i did get it off the ground. hit a fence.
Old 10-08-2007 | 08:31 PM
Missileman's Avatar
ORIGINAL: jdv123
perhaps finally breaking it in? i did get it off the ground. hit a fence.
I am not sure that is what "Breaking it In" really means
Old 10-08-2007 | 08:38 PM
does 30 seconds in the air = solo
just messing.
learning, hurting, learning some more.
Old 10-09-2007 | 12:04 PM
MinnFlyer's Avatar
Exactly what type of battery/charger are we talking about here?
If you have a standard 600 or 800mah Rx pack it would take about 16 hours to charge with the charger that came with your radio
Old 10-09-2007 | 01:07 PM
Minn - this is the plane
http://www.rctoys4us.com/product/AR-NN-TD-RTC2016
and these are the battery/charger specs
http://www.rcuniverse.com/forum/fb.asp?m=6463949
Old 10-09-2007 | 01:22 PM
MinnFlyer's Avatar
Oh
Old 10-09-2007 | 01:24 PM
RCKen's Avatar
My Feedback: (9)
Thanks Mike, I needed a laugh!!!
Ken
Old 10-09-2007 | 01:28 PM
Gilda and Minn look alike ya know?
Old 10-09-2007 | 01:29 PM
MinnFlyer's Avatar
Yea, but only since she died
Old 10-09-2007 | 01:31 PM
RCKen's Avatar
My Feedback: (9)
ORIGINAL: MinnFlyer
I've seen Mike after 9 pm. Trust me, it's hard to tell that he's alive too!!!!
Ken
Old 10-09-2007 | 01:45 PM
CGRetired's Avatar
Old 10-09-2007 | 04:59 PM
Gary L.'s Avatar
ORIGINAL: RCKen
ORIGINAL: MinnFlyer
Ken
LOL, That hurt........
Old 10-10-2007 | 01:19 PM
aryajet's Avatar
ORIGINAL: MinnFlyer
Oh
