 Ball link on Throttle arm? >
Old 10-10-2007 | 04:29 PM
My Feedback: (13)
Default Ball link on Throttle arm?
Is a ball link on the throttle arm on the carb a good idea?
Old 10-10-2007 | 04:41 PM
Default RE: Ball link on Throttle arm?
I use them on all my planes. I use the plastic ones and solder the adaptor to a throttle cable. It makes for a clean hookup. They hold on well and after a crash that totaled out the plane, ripping the engine and firewall off the plane, the ball link was still attached. I run four strokes, so clearance to the firewall is sometimes an issue. In those cases, I cut the adaptor down and also cut the body of the ball link off. I can gain about 3/8" to 1/2" this way and that is usually enough to keep the linkage from hitting the firewall at extreme travel.
Don
Old 10-10-2007 | 05:00 PM
I like these on the throttle. Don't need to open up the holes in the carb arms.
http://www2.towerhobbies.com/cgi-bin...&I=LXD900&P=SM
Old 10-10-2007 | 07:29 PM
WMB
ORIGINAL: bruce88123
These are my favorite also.
Old 10-10-2007 | 07:43 PM
Same here. Just remember to put a spot of thread lock on the nut. I had one come off in flight. Wide open throttle with a full tank. Seems like forever before it ran ou.
Don
Old 10-10-2007 | 09:26 PM
I keep forgetting to mention the obvious.
Old 10-11-2007 | 09:04 AM
Charlie P.'s Avatar
Throttles are the most forgiving of control movements on a model. Throttles and nose wheel steering rods are the only place I use Screw-lock connectors.
The ball-socket connector with a "Z" bend or Fastlink at the servo arm is much improved over the screw-lock method.
Old 10-11-2007 | 09:06 AM
BarracudaHockey's Avatar
ORIGINAL: Campgems
Don
hehe my buddy lost his with a gasser running just above 1/4 throttle, too fast to land but it took like 45 minutes flying in circles to run out the gas.
Old 10-11-2007 | 10:07 AM
Hi!
Not that good ! A plastic snap keeper is much easier to unlock and trim.
Old 10-11-2007 | 11:26 AM
The ball link makes an excellent throttle attachment, especially if there is a slight offset between where the pushrod exits the firewall and the throttle arm is.
Old 10-11-2007 | 12:01 PM
And not metal to metal either.
Old 10-11-2007 | 06:38 PM
hey guy ... you and I read the same book!! egg-zakly how I set throttle up also. Works great, and no slop, etc
Bruce
Old 10-12-2007 | 01:29 PM
hogflyer's Avatar
I've been using ball-links for throttles for around 30 years and haven't have any problems with them.
Hogflyer
Old 10-12-2007 | 05:21 PM
You can't go wrong with ball-links .
Old 10-12-2007 | 06:43 PM
Make sure there isnt any side force on the ball link
had one come off in flight.... Sait carb closed itself because of the spring.....
Steven
Old 10-18-2007 | 05:53 PM
ORIGINAL: Charlie P.
you must make GOOD solder joints . i HAVE USED ez CONNECTORS FOR 25 YEARS WITH EXCELLENT RESULTS, LIKE anyOTHER CONNECTOR(AND THERE ARE DOZENS OF WAYS TO DO IT) YOU MUST UNDERSTAND THE PROPERTIES OF EACH METHOD.
