 Muffler Positioning...How critical? >
Old 10-24-2007 | 08:11 PM
Mdhat's Avatar
Default Muffler Positioning...How critical?
I have a nexstar with a SuperTigre 40 and a straight Tuned Muffler. Every run I cover the side of the plane with oil, can I tip the muffler down to clear bottom of plane. Or is that not recommended?
Old 10-24-2007 | 08:22 PM
Campy's Avatar
Default RE: Muffler Positioning...How critical?
You can tip it down.
Old 10-24-2007 | 08:27 PM
You can also use an exhaust diverter on it. They are extensions that put the exhaust into the airstream a bit farther away from the airplane.
Sometimes where you point the exhaust works wonders. And sometimes just a bit further out is enough.
Old 10-24-2007 | 08:32 PM
Mdhat's Avatar
Thanks, didnt know if it would push up nose to fast or screw up air flow.
Old 10-24-2007 | 08:58 PM
bobmac010's Avatar
The diverters work great. I had a homebuilt where the plane was soaked w/oil... I installed a diverter, and I basically did not have to clean the plane after each flight anymore. A little Fantastic, adn in the back of the Suburban it went...
Old 10-24-2007 | 11:03 PM
http://www3.towerhobbies.com/cgi-bin...&I=LXL378&P=ML
Old 10-25-2007 | 06:25 AM
mclina's Avatar
I use a deflector on my Alpha trainer, and it does a great job of keeping oil off the plane. On my Four Star, I have actually run a plastic tube from the muffler and tie-wrapped it to the landing gear. I took out the muffler baffle to compensate for the added resistance, and it works and sounds great (OS 46LA).
I am putting a Super Tigre 45 on my current build. Those mufflers are pretty bulky. I would expect to get some resistance from it if it is tipped too far. I am planning on a deflector for that as well.
Old 10-25-2007 | 10:11 AM
I am getting one for my trainer, it gets soaked in oil.
Old 10-25-2007 | 10:37 AM
Campy's Avatar
A tip for you folks using (or planning to use ) exhaust diverters.
The diverters have a NASTY habit of coming off (usually in flight ) and being lost.
Take a Dremel OR a small triangle shaped file and cut 2 shallow grooves all the way around the exhaust nipple on the muffler.
When you put the diverter on the muffler, use a small hose clamp to secure it in place instead of the plastic zip-tie.
The hose clamp wil force part of the diverter into the grooves and prevent it from falling off.
Old 10-25-2007 | 02:29 PM
Gary L.'s Avatar
Good idea Campy.
Old 10-25-2007 | 03:59 PM
ORIGINAL: da Rock
I agree with Rock. I have used diverters for exactly what you want to correct. They are inexpensive, very light and don't add weight and can be set up without altering your existing muffler.
